Brand: whirlpool direct drive duet washer front load
Model Number: wfw8540fw1
Main Symptom: metal washer drum access between the tub assembly
What happened: i need to fully scrub or get a brush to scrub the backside of the metal drum between the tub assembly.
Already tried:
I’ve taken off the filter/drain pump compartment at the bottom of the tub, to expose a 3inch whole just wide enough to run a scrubber between the metal drum and plastic tub assembly/housing. ive taken the top drain tube to also expose another 3 inch opening but i need a more thorough tool or way to scrub the entire metal drum not just the 4 -6 inch radius around the hole’s entry point that i can access with my fingers and a scrubber.
I’ve used washer tablets, and i purchased animal grade washer cleaning tablets as well and nothing has worked. i can see and wipe, a film on the backside of the metal drum. I need to find a tool that will fit in there OR find a better access point, so that i can scrub the metal drum entirely. any insight??
I can see that the drum is sealed with a white glue under the copper clasp pins that hold the front and back of the washer tub assembly together, so without breaking the seal, cleaning and re-gluing back together… is there another way technicians would clean the backside of the metal drum (between the tub assembly and the metal drum??)
