My dryer has been squeaking loudly (Giant Hamster on rusty wheel) for a few months and now I can not stand it any longer and I need to do laundry!
I figured out how to take the front off and I want to make sure I order the correct parts to attept to fix the problem and tips on how to replace them.![]()
Replacement parts for DE312 models | AppliancePartsPros.com
There are a number of thinks that can cause the racket.
Rear support wheels Item 30 in Section 8
Front glides (bearing) Item 24 in Section 8
Motor bearings
Idler wheel Item 19 in Section 5
Something jammed between the drum and the unitโs frame. Bra wires are famous for this.
Something has fallen into the blower.
Check the parts for any signs of wear, overheating or slop.
