Need Electrical Schematic Diagram
Troubleshooting failure for drain motor to turn off whenever on button pressed and dishwasher won’t go through cycles. Need electrical schematic diagram. Thanks, Fred
Remove the toe panel and check for water in the base under the dishwasher. Most likely there is a water leak.
You can find the quick check chart in the break down diagrams for the Bosch dishwasher Model SHU3036 UC/12 (FD 8003-)
Gene - thanks for the reply but no help - I’ve already looked at the diagrams referenced and need the electrical schematic diagram. Also, no leaks - pump motor just keeps running and it won’t respond to any other command (like wash). Please send the electrical schematic diagram if available. Thank You, Fred
Fred,
You can use the troubleshoot manual from one of our previous posts: http://forum.appliancepartspros.com/dishwasher-repair/7123-bosch-dishwasher-troubleshoot-manual.html
Unfortunately I do not have the wring diagram for this model.
Gene - You are the Man!! I followed the guide in the previous posts - actually started there. It runs out of gas and really need the schematic diagram - Bosch won’t supply it as I’ve tried. Appreciate your time and posts and wish you the very Best Thanksgiving Holiday! Fred
