Nautilus
I have a GE Nautilus dishwasher and it is not going through the cycles. It is draining and running fine but it just keeps on running and running stuck doing the same thing unless it is filling up. It has a dial on it and it does not appear to be moving on it’s own.
What is the complete model number of the dishwasher?
The model # is GSD2600G02WW
Open the control panel and check the switches on the left side. Probably one or two of them are fried.
If there is nothing wrong then the problem most likely is a bad timer.
Here are the breakdown diagrams and Replacement parts for GE GSD2600G02WW | AppliancePartsPros.com
