Quick Insight, I Took The Bottom Of My Whirlpool Quiet Partner 1 Apart To Get To The Drain Area Where I Cleaned Out A Lot Of Gunk And Hard Water Build Up. I Put Everthing Back Together, And Now When I Run The Dishwasher The Dial Doesn’t Move And It Keeps Running And Running Unless I Manually Move It To Rinse And It Will Go From There To Drain And Dry. Please Help.
Check the wires to the heating element and high limit thermostat. Check both parts for continuity. If you need the correct part numbers, post the complete model number of the dishwasher.
