My washing machine is making a ratchety noise when it agitates
Brand: ge
Model Number: gtw335asn2ww
Main Symptom: noise
What happens & when:ratchety when agitating
Error Code (if any):it has errors but i dont know what they are. All the lights are lit up except deep rinse
Is it making the noise in both directions of agitation or just one? Does the noise seem to be coming from under the washer or inside the tub, if you can tell?
That code is for an out-of-balance condition, shouldn’t really be related to this issue.
Well i pulled it out while looking things up and turn it backwards so that can be why.
Cant tell if its inside the tub or not. I can say its not when it spins. Its not when it fills. As its washing, it will make this noise. It started some time in then past several months and i would hear it momentarily on occasion. Now its all of the time in every wash. Louder and worse.
I also took the bottom cover off. No white flecks. I took the agitator off and cleaned it, i also clean the bottom of the basket, there was a pile of muck on the shaft and nuts. It has some corrosion and rust. I cleaned it up as best i could. I got online with your robot and asked questions and took pics as well. It had me run tests.
The first place I’d probably look is at the splines and bottom of the agitator WH43X30957. If you pop that dispenser cup out of the top of the agitator you should have a bolt under it holding the agitator on the gearcase shaft. Take the bolt out and work that agitator back and forth while puling up to get it out. Then take a look at the splines inside the bottom of the agitator to see if they look worn or stripped.
Is there a way to send pics?
You should be able to attach them directly to this thread in the reply.
Do you have pictures of the splines in the agitator itself?
The splines in the agitator look pretty eat up and the ones on the gearcase WH03X33729 are worn. I’d suspect that’s the cause of the noise.
You could try running an empty cycle to see if the noise goes away. If it does then I’d suspect that the splines are slipping under load. If it doesn’t, run the same cycle again but with the agitator out of the washer.
If you’re still getting the ratcheting noise during agitation even with the agitator out then you’ve either got a clutch gear WH05X24185 slipping or an issue inside the gearcase itself.
I did run a cycle empty and it did still make noise, not as much, but it did. I will try another one without the agitator in it on Monday, when i get back in town. Thanks
