Brand:Maytag Model Number:MGD8100DW0 Main Symptom: Flashing Sensing Light but won’t Start What happens & when: When I hit the start button I hear a click but the “Sensing” light just keeps flashing but will not start. Even when I put it on Timed Dry
Error Code (if any):F2e1, F4e3, F3e6
Parts or tests already tried: Put new motor in, idler pully, tested thermofuse
The F2E1 will indicate an issue with a stuck button on the UI and would need to do test 6 on page 20 of the tech sheet. The F3E6 Will be an open moisture sensor and will need to do test 5 on page 19 of the tech sheet and the F4E3 is a restricted air flow error and you will need to do test number 4a on the thermistor page 16 and then check the venting.
