My refrigerator is dispensing water out of the door after it harvests the ice
Brand: Frigidaire
Model Number: grsc2352af1
Main Symptom: dispensing water when not calling for it.
Parts or tests already tried: already tried replacing the dispenser control board
Check if the ice maker is filling when you dispense water. If it isn’t then your issue is most likely the valve AP8065822. The dispenser valve and the ice maker valve will get a certain amount of voltage while the other is active due to how they are wired into the system and connected to the each other. If one of the solenoids is getting weak it will let water pass when the other valve is activated.
https://www.appliancepartspros.com/frigidaire-solenoid-assembly-140137975102-ap8065822.html
I am still getting ice. No problem there. You can hear the water fill up the tray for ice then a minute or 2 pause and the then the water comes out of the door dispenser.
