My oven isn't heating and was told that Range Oven Temperature Sensor Probe for Electrolux FFGF3047LSH Element will not heat Frigidaire will do the job .. can you help troubleshoot before i order the part, and also can you provide a link to video i view
Brand:Frigidare
Model Number:FFGF3047LSH
Main Symptom:oven not heating up
Error Code (if any):none
Parts or tests already tried:none
This could be caused by a few things such as a failed igniter, oven sensor, wire, control, or even the gas valve. If the floor of the oven is removed, does the igniter turn on and glow when a bake cycle is started? If it does, the most likely failure would be the igniter itself. If it does not glow, voltage testing would be the next step to identify if the igniter is receiving 120 Volts AC from the oven control. Let me know what you find and we can go from there.
