My kitchen aid dishwasher has power but will not start
Brand:Kitchen aid
Model Number:kdfe104hwho
Main Symptom:no power
What happens & when:nothing no flashing lights
If a multimeter is readily available, a voltage check can be done to see where testing may need to proceed. With the outer door panel removed and the main control accessed, what reading do you find if you test for Volts AC from the black wire to the white wire on the far left of the main control?
