When the oven is turned on, does the igniter glow? If it does, the igniter is the most likely issue. If not, there is some tests that can be done. Let me know what you find with the igniter glowing and we can proceed from there. 5304509706 Gas Range Oven Igniter | Genuine Frigidaire OEM In Stock
