My Frididaire dishwasher is spitting water from under the door
MY dishwasher has been spitting water out from under the door onto my new floors. My husband replaced the door gasket and no improvement. The water sits in the lip under the door and during the cycle it spits it out. Please help before we spend another $400 on a new dishwasher when we have only had this one for 2 years.
Replacement parts for FRG FDB1050REM2 | AppliancePartsPros.com
You said new floors was the dishwasher moved when these were installed.
Could be it is not level.
Take a look at TechnicianBrian’s site, scan down the dishwasher or frigidaire sections. He has a good blurb on the bottom seal
(Frigidaire Dishwasher Leaking from the Door)
Appliance Repair Blog
Check that a spray arm hole is not partially clogged or the arm is cracked. Sometimes this will cause the water to spray at a weird angle causing a leak.
Thank you for your response. No the dishwasher was not removed and it was leaking before the new floor install. My husband checked the level first thinking that if it was pitched forward a bit it would cause the water to pour out the front, but it was level. Any other ideas would be appreciated. I wil have him check for clogs !
