My freezer coils are frozen
My freezer coils are freezing up. Lower compartment has no cool air circulation because of this. Have defrosted and same thing happened again after about 3days. Fan is working properly. Is this a thermostat issue? If so, where is it located?
Replacement parts for AMANA ATF1836ARW REF - TOP MOUNT | AppliancePartsPros.com
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 2 in Section 2) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it’s rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 13 in Section 3) from the wiring and measure it for continuity, usually around 30 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 18 in Section 3) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK. Looks like it has a built in resistor so when o[pen it will probably measure around 30,000 ohms.
Your unit also has a fuse (Item 16 in Section 2). It should be 0 ohms.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
ATF1836.pdf (158.4 KB)
