My Dryer Won't Heat
I moved the unit and vaccumed it and now the dryer will tumble the clothes but won’t produce any heat. We have checked Fuses/ voltage/ continuity. What next? Thanks:confused:
Check resistance on heating element, it should be in the 8 to 12 range. Also check to make sure all the connections are secure.
It may be that the heating element was brittle and broke when you moved it, our that a loose connection occured from the move.
