My dryer will not stop when clothes are dry
Brand: GE
Model Number: GTD45easj2ws Won’t stop when clothes are dry
Main Symptom: Doesn’t stop
What happens & when: Clothes are dry and I need to open door.
Hi Trader Joe,
Just to make sure I understand correctly, are you saying that when you open the dryer door, the drum continues spinning, or that the heating element stays on even after the door is opened?
NO. I say my clothes keep drying and the dryer will not stop. Until I open door.
If this happens on the timed dry cycle, the issue is likely to be a timer issue. If in the auto cycles, then the issue is with the auto board circuit.
Any part numbers to order? Install video?
