My diswasher works when it wants to
Please help. mY DISWASHER WORKS WHEN IT WANTS TO. I CAN PUSH ANY BUTTON AND THEY WILL LIGHT UP SOMETIMES & SOMETIMES THEY WONT LIGHT UP. IF THEY DO LIGHT UP AND I PUSH START NOTHING HAPPENS. I HAVE TO GO DAYS WITHOUT IT WORKING AND THAN ALL OF A SUDDEN I’LL TRY AGAIN AND IT WORKS. BUT IT WILL ONLY WORK FOR ONE LOAD. IF I UNLOAD IT WHEN IT’S DONE AND RELOAD IT TO WASH AGAIN IT WONT WORK. HELP PLEASE..I HAVE TRIED TURNING BREAKER OFF FOR A FEW HOURS, LEAVING THE DOOR OPEN OVERNIGHT. NOTHING SEEMS TO WORK
Replacement parts for Maytag MDBTT60AWB DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
Please turn your cap lock off.
No one likes being yelled at.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
Remove power from the unit when working on it.
If the unit is connected to the line by wire nuts. Remove them and then re-install to be sure that they are OK.
Check that the door switches close could be one of them is just on the edge of closing.
