My D140 front eye only went to high, no matter what # it was turned to and now neither eye works at all
Brand: JennAir
Model Number:D140
Main Symptom: Eye overheated
What happens & when: overheated and then stopped
Parts or tests already tried: I tried another eye, and it worked, but went to high even when turned to “6”
Might it need a new Range Top Burner Infinite Switch or a new Cooktop Burner Control Switch, or both? Are all the Cooktop Burner Control Switchs the same for each eye, or is there a different one for the 6" versus the 8" eye? I appreciate your help!
You can use the same switch for each of the elements. Here is a link to the part number. Whirlpool W11120795 Cooktop Range Top Burner Infinite Switch | Genuine OEM Part
