Mounting DIshwasher
Hey Guys…I have a dishwasher that i need to secure to my granite tops. I can not side mount as i do not have enough cabinetry to drill into. Several installers I know have recommended Granite Grabbers…from the website they look like they simply adhere to the countertop, and appear to be pretty neat. Has anyone used them? They are pretty cheap I might just order a set.
The bottom part of the counter top usually made of wood or plywood, so you can easy screw the dishwasher top mounting brackets into it.
[quote=Gene;114537]The bottom part of the counter top usually made of wood or plywood, so you can easy screw the dishwasher top mounting brackets into it.
Gene.[/quote]
Actually i have no wood under my tops and hate the look of wood glued to the bottom. I actually ordered my Grabbers from an installer that had them in stock and they worked awsome. Very low profile…and they installed in 5 minutes…
I would definately recommend them and i believe you can order at Granite Grabbers LLC - Home
Thank you for sharing this information with us.
This Forum is great! I am glad to participate…and have found much good information here.
