Motor Replacement
I need to replace the motor on a dishwasher. I’m fairly handy but I have not attempted something like this before. Is it very difficult (lots of parts to remove and put back in the correct order) or should I attempt it?:confused:
Replacement parts for WHIRLPOOL KUDK01ILBS1 | AppliancePartsPros.com
And here is the tech sheet with info on the motor install
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
