I have removed the Toekick plate and can see the motor to my right.
It will not move. How do I turn the motor . I can unplug the unit and then restart the unit. What type of a tool should I use the move the motor blade? Roy
Just use two flat blade screwdrivers to free up the motor, most probably just the pump seal froze up, usually happens if it was not used for a while. Then dump a half gallon of vinegar in it to dissolve calcium and soap residue from the pump.
Thanks Richappy.![]()
