Motor drains but wont wash
DW fills and pumps out but evidently the motor is not reversing any ideas?
I cannot find any info on your Model Number but if I look up other KUDL01 units none of them have a reversing motor.
Perhaps the following will help
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4e8b0d2df77cd7e585256cd800643b6d/$FILE/KD01.pdf
I would check the motor windings for continuity with a meter.
If OK
I would check to see if it is getting voltage when it should.
If OK then and the motor turns by hand (not jammed) then it is toast.
If no voltage
Check that the wires have continuity back to the control board.
If OK
Then probably your control board is toast.
