Brand: whirlpool
Model Number: wtw5010lw
Main Symptom: error code F9E1
What happens & when: always goes to this code after restarting and trying any cycle.
Error Code (if any): F9E1
F9E1 is a long drain/no drain code. If the drain pump won’t run the machine won’t really let you do anything else.
You can check the resistance value of the drain pump W11399437 at the pump itself, should be about 17-22Ω.
If that’s good check the lower harness W11643701 for any obvious damage and replace if it is damaged.
If both of those are good then the issue is with the main control board W11513246.
https://www.appliancepartspros.com/whirlpool-pump-water-w11399437-ap6974144.html
https://www.appliancepartspros.com/whirlpool-harn-lower-4-w11643701-ap7205722.html
https://www.appliancepartspros.com/whirlpool-cntrl-elec-w11513246-ap7019124.html
