Brand: Monogram
Model Number: ZDT870SPF7SS
Main Symptom: not cleaning and water not getting hot
What happens & when: dishes are not coming clean and even a little butter in a butter dish is still there after a cycle so it’s not getting hot
Error Code (if any):16, 48, 49, 80
Parts or tests already: I put in a new turbidity sensors and still not working. I took out the sensor and tested the outer pins for impedance. It read open. I went to the parts store and checked the other sensors and all tested open. I ordered a part from GE and it tested open. When I put the new part direct from GE in, it threw 48/49 for the first time. I understand that the turbidity sensor has a thermistor in it so the codes lead me to believe the sensors is bad. If I’m testing it wrong or the sensor is good I would move to the wiring harness and then main board. I need help to ensure I’m testing this correctly.
