I have just recently replaced the timer on my dishwasher, the timer moves under its own power, the first cycle (NORMAL) works perfect {pumps out- followed by fill then wash starts then pumps out the second cycle light nothing happens the timer moves but nothing happens, the china crystil cycle fills and washes but will not pump out the timer keeps moving on its own and when the dry cycle is over the water is still in washer.
Do you have any ideas or recomend parts you have that may fix issue.
Thank you
