Microwave tripped the breaker, i reset. Now microwave does not work, is there an internal fuse that needs to be replaced? Where is it located?
Brand:Samsung
Model Number:smk9175st
Main Symptom:Not working
What happens & when: Tripped the house electrical breaker, I reset it. Microwave worked for a few seconds, then stopped working. Breaker not tripped. Is there an internal fuse? Where is it located.
There is a small 20A fuse on the filter board behind the grille and control box. If that blew it is likely you will need to replace the door switches which could have been caused by a bad control board, the high voltage components failing, or the blower motor going out.
