HI. I am replacing my water intake on the dishwasher and wonder if it makes any difference which way I connect the electrical back to the connectors on the intake. The manual doesn’t mention it so I’m guessing it’s not important but I though I’d put the question out there to make sure. I know, I should have remembered how it came off in the first place.
Thanks for any help.
D.
Here are your parts includes a wiring diagram.
Replacement parts for MAYTAG MDBS561AWB DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
I am assuming you are talking about the water valve (Item 2 in Section 6).
It does not matter which wire goes to which connector on the valve.
