Maytag
dryer stoped heating need part easy to fix?
Dan,
What have you done so far ?
Best quick guess, at this point would be a broken igniter, of there’s no heat at all,
Second guess would be a bad set of valve coils, if it’s an intermittent heat or noise during dry cycle.
Have you removed the front panel and observed the gas valve for operation ?
