Maytag
washer doesn’t work after we close the front panel but it will work if you push the panel in or apply a little pressure on the latch release. I suspect the latch is bad. Any suggestions?
Check number 8 on this diagram (may be able to adjust it) and numbers 5 and 10 on this diagram.
