Maytag WU284 will not advance thru cycle
Maytag dishwasher wu284 will not advance thru the cycle. It will fill with water and heat it but not progress to the next cycle. If the knob is turned manually it will advance to the next cycle and perform that cycle until the knob is advanced again. I see in the parts list the timer and timer motor are two separate parts. The timer is no longer available from Maytag. I have done continuity checking on the timer motor with a multimeter and it seems to check ok. I do not have a repair manual and did not check anything else. Is there another test I can perform to prove the bad part is the timer motor? I do not want to just swap parts to see if they will work. Thanks in advance for any input.
[FONT=Arial][COLOR=#000000]Dear [COLOR=black]Ckinross38,[/COLOR][/COLOR][/FONT]
[COLOR=#000000][FONT=Arial]We are sorry to hear about the problems you’re experiencing with your dishwasher. My name is David and I work for the Sears Home Services Team. Sears provides service to our customers to virtually any location within the [/FONT][FONT=Arial]United States[/FONT][/COLOR][FONT=Arial][COLOR=#000000] and we would like the opportunity to help you if you are considering service on your dishwasher even though you may not have purchased your machine from Sears. We do not want to supersede the valuable assistance this site provides as they are very good at handling issues for it’s members, but I wanted to reach out and offer our services if you decide you should need them. At your convenience, please contact our office via email at [/COLOR][COLOR=navy][COLOR=#0000ff]SearsHomeSvc@searshc.com[/COLOR] [/COLOR][COLOR=#000000]with any questions regarding our service options or to schedule a visit from a Sears certified technician. In your email, please provide a contact number and a brief description of the symptoms you are experiencing with your dishwasher and we will call you at your convenience. In addition, please include your screen name Ckinross38 used to post on this site, for reference to your issue, and we do look forward to talking to you soon.[/COLOR][/FONT]
[FONT=Arial][COLOR=#000000]Thank you,[/COLOR][/FONT]
[FONT=Arial][COLOR=#000000]David V.[/COLOR][/FONT]
[COLOR=#000000][FONT=Arial]Sears[/FONT][FONT=Arial]Home[/FONT][FONT=Arial] Svc[/FONT][/COLOR]
The problem can be a bad gears inside the timer as well as a power failure to the timer motor. Without the proper wiring diagram I can not tell you where the power to the timer motor is coming from.
Very likely the problem is a bad timer and you probably have to look for a new dishwasher.
I saw on another website that the proper procedure for continuity checking is to unplug the wire clips before checking the timer motor with the multimeter. It did not pass the test this time so I ordered a timer motor. The installation of the timer motor is very simple (two screws and two wire connectors). After the timer motor was installed the dishwasher is back to normal.
