Maytag will not fill
The dishwasher was not filling everytime. I replaced the water inlet valve and the float switch. Still would not fill.
I pulled the door cover off and looked over the control board. I noticed a darkened (scorched area) so assumed (bad idea) that the board was the problem.
I replaced the circuit board and still not filling. I checked water coming from the water line, Ohm on the valve etc.
I have read that there is a diagnostic sheet under the kick plate but it appears mine is gone (I see a pouch where it used to be (had it worked on a few years ago). I did see how to enter the manual test mode and I did that but did not see anything that pointed to the problem. No error codes.
I am at a loss as to what I should check next. Is it possibile that I have a broken wire somewhere? Does anyone have the diagnostic sheet for this model?
Found the problem. At the bottom of the door, under the panel, a metal piee had cut some wires which shorted out the original control board.
Fixed the wires and it all works.
Good job. We are glad you were able to fix it.
