Maytag washing machine: MVWB765FW0 dripping from the soap dispenser and wet clothes after the spin cycle
Brand: Maytag
Model Number: MVWB765FW0
Main Symptom: dripping from the soap dispenser when the washer is not in use and very wet clothes after the spin cycle and oxiclean is not being used when it should be
With water flowing out of the dispenser when the unit is not in use, this will likely be an issue with the water valve not fully closing and would need to be replaced.
https://www.appliancepartspros.com/whirlpool-valve-w11165546-ap6284346.html
