Maytag Washer Rise Cycle
I have a Maytag model MVWC565FW1 top load washer. During the rinse fill cycle, the washer will start to fill for about two minutes, then sit for about 4 minutes, then fill for about two minutes again, then sit for about 4 minutes. This process continues until the washer is full and then the rinse cycle will proceed. I have checked the water inlet screens. Also, the flow rates for the hot and cold water appear to be about the same. The washer is about 5 years old and was working just fine up until a few weeks ago. Any insight would be greatly appreciated!
