Maytag washer Main control board (ACU) removal l
Brand:Maytag
Model Number: MHW5630HC0
Main Symptom: How to re
Error Code (if any): F6 E2
Parts or tests already tried: Changed UI unit and did not help. Now will try replacing main control board ACU
​@appliancepartspros I want know how to remove this ACU W11291151 from Maytag washer model MHW5630HC0 same as the one shown in the video. Video does not show how to remove the ACU but it shows how to put it back. I tried pull backward and does not budge.Please help. Thanks
On the back of the washer close to where the bottom of the ACU would be, there should be a screw. This is used to secure the ACU in place so that it does not vibrate loose during machine operation. Once it is removed, the ACU should be able to slide toward the front then pull away from the wall.
