Maytag Top loading washer MVWC565FW2 doesn't have warm water
Brand:Maytag
Model Number:MVWC565FW2
Main Symptom:no hot/warm water
What happens & when:Water comes out cold no matter what water temp we have it set on. I took the hot water hose off the back and ran it into a bucket and it has good flow. The water does come out warm if we turn the cold water off. Is it a temp selector or is it the valve?
Parts or tests already tried:I took the valve out and tried to clean it because there is well water running through it. A lot of sediment came out but it still seems dirty. I also checked the voltage at the solenoids (I think I said that right???)
This issue could be with the valve, the thermistor, or the control. I am attaching the tech sheet, which has the self-diagnostic instructions.
tech-sheet-w11420433-reva (1).pdf (492.3 KB)
