Maytag Panel shows 21
My control pannel shows 21 and won’t change unless I reset the power
What does it do at this point? Does it wash, drain or stays silent?
What does it do after you reset the power?
Here are the breakdown diagrams and Replacement parts for MAYTAG MDB7601AWW DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
Gene sometime it resets and works and sometime I have to leave it shut down for a while to get it to reset.
It will work as I said then sometime I have to leave it off for a while and then it will reset and work again
[QUOTE=Gene;327688]…What does it do at this point? Does it wash, drain or stays silent?..[/QUOTE]
I still need you to answer this question.
[QUOTE=Gene;327688]What does it do at this point? Does it wash, drain or stays silent?
Gene.[/QUOTE]
When I get it ti reset it works it does everything wash drain dry it totally works and every now and then it goes back to 21 and I have to reset it again and then it will work again totally for a while
Sounds very unusual. It can be a loose connection somewhere as well as a bad control board.
If it does it not very often I would keep use the dishwasher until it will die.
