Maytag only runs rinse and Insta Wash
Maytag Dishwasher Quiet Series 300 MDBH975AWW 5 years old.
Only the Rinse and Start/Cancel buttons work. Rinse rinses, and Start/Cancel runs the Insta-Wash (most likely the most recent mode selected prior to the problem). No other lights or buttons appear to function.
Ribbon looks ok- cleaned and reseated, inside the front panel is clean and dry. Based on previous posts, I’ll need a control board and/or control panel. Which part numbers are intended for my model?
Thank you for your time.
[quote=bdillon77;469453]Maytag Dishwasher Quiet Series 300 MDBH975AWW 5 years old.
Thank you for your time.[/quote]
B,
Here is the part number for your control panel/keypad assembly.
I’m thinking thats about all you’ll need, to be honest.
There are 3 different control boards, and thats based on the series/serial number of your unit.
If your tech data sheet is still with the unit, it should be attached to the back of the kickplate panel on the bottom of the unit, in a plastic bag.
It’ll give you most of the test procedures and test programs so you don’t get lost or go off the deep end.
AP4364367
