Maytag MVWC565FW2 spin cycle is waaay out of whack
Hi all, new guy here.
I have a Maytag washer that wobbles terribly on the spin cycle; it’s less than 6-7 years old, purchased new at Lowe’s. It’s so bad that the washer shakes terribly and wanders as far as the hoses will let it. The spin cycle never completes, and the washer quits trying after 3-4 attempts.
I’ve already changed the suspension rods for new ones from an aftermarket kit I bought on amazon. AI seems to suggest that if you push the tub down, and let it go, and it feels springy and bounces more than once or twice, the rods are to blame. However, I would say it has about the same bounce as before. (and the same wobbly spin cycle symptom.)
Heres a vid of how bad it gets: Dropbox
Any ideas what else I can try? It doesn’t seem there’s much to replacing the rods, it was relatively straightforward, I’d be surprised if I did something wrong.
G
OK 2 things
  1. Aftermarket Suspension Rods are notorious for not fixing unbalance issues just like you are experiencing, due to substandard manufacturing and materials especially in the quality of the springs. Always use OEM parts, In your case the part # you need is (Whirlpool W11130362 Washer Suspension Rod Kit | Genuine OEM Part)
  2. Did you inspect your tub and cabinet for any damage that may have occurred from the original spin issues and have you ensured the unit is as level as possible?
Are you experiencing this issues with all types of loads?
Does it vibrate even when spinning while empty?
Yeah, I’m starting to think it was the cheaper aftermarket rods that weren’t good enough. It actually seems worse now than it was before I replaced them.
I didn’t specifically look for any spin damage, but to my casual observer’s eyes, the tub/spin basket/etc. seemed normal. The foam pads on the inside of the washer body are beat to hell, though :smiley:
It seems level enough to me. I could very slightly rock it across one diagonal axis compared to the other, so I bumped up the height on one foot to compensate slightly. But it was verrrrry subtle anyway: no physical gap in the feet; it just didn’t feel as solid as the other axis did.
All loads cause the wobble. Occasionally, the washer might finish a cycle without abandoning the spin if it’s a very light load, but 90% of loads will terminate prematurely. I ran an empty spin cycle yesterday, and it did complete on its own. The wobble was drastically less on the empty cycle, but it still seemed like more than it should be, maybe?
here are a few vids if this helps diagnose anything:
washer shake with factory springs
washer shake with aftermarket springs
Empty Spin cycle with aftermarket springs
push test with aftermarket springs
Thank you!
G
Do you think it’s worth checking anything else before I order the rods? Claude wanted me to look at some things under the washer plate, but to my mind those seem related to how the inner tub spins inside the fixed outer tub more than the shaking I’m seeing.
Definitely would suggest new OEM springs, ensuring level and some people have good results putting a rubber mat or a piece of plywood under the washer (although I am not sure if it’s necessary).
One thing when it is completely empty move the basket around and see if you hear any sloshing sound. I’m wondering if the liquid in the counterbalance on the bottom of the basket has leaked out.
Hmm, ok - I have heard water sloshing around in the bottom, but I don’t remember if that was after an aborted spin cycle or not, and I’m not sure if the washer would normally pump out any remaining water in that case.
It sounds like there should be a sloshing sound then?
My gut says the springs will fix it, since it seems to be slightly worse with the aftermarket springs, so I’ll order those and give it a go.
Yes after the washer drains all the water there will be liquid remaining in the counterbalance ring on the bottom of the basket, so after all the water has drained you should still hear a sloshing as you move the basket
ok, thanks Jeffrey - I’ll check that tonight, but ordered the replacement rods just now anyway.
