Brand: Model Number: Main Symptom: MVWC565FW2 What happens & when: Violent Shaking/jumping & Loud banging, but bought suspension rods from you and installed, still shakes but not as violent AND very loud banging on last spin cycle.
Hi, did you make sure the washer is completely level? Also, when you replaced the suspension rods, did you replace the hubs/bushings that the rods sit in as well? If those are worn or not seated correctly, the tub can still move around too much and cause banging or balance issues.
For the next step, with the washer empty and turned off, push down firmly on the center of the basket and release it. The basket should come back up and settle fairly quickly. If it keeps bouncing several times or feels loose from side to side, recheck that all four suspension rods and their hubs/bushings are fully seated.
If that checks out, run an empty spin cycle and watch the basket. If it stays stable empty but starts banging with clothes inside, we can narrow it down further from there
Did this before ordering and replacing all four suspension rods - purchased kit from Appliance Parts Pro - kit included hubs/bushings and were replaced and appeared to be nicely seated.
After installing suspension rods, ran a small,light load - machine shook a lot during spin cycle, but did not jump around as before. When I put a normal load in - machine shook and banged - on the final spin cycle the banging was very loud.
I could not upload the video I took on my phone.
I have bought Maytags for decades and always satsified - except for this problem and purchased approximately 4 years ago.
forgot to tell you - earlier put a level on machine and it was level - actually did all these steps BEFORE replacing the suspension rods. After replacing suspension rods, did a recalibration.
I used the middle dial and turned to rinse & spin, however, the machine did a full wash.
Unfortunately, even with the washer totally empty, the shaking and loud banging persisted.
It appears that the tub is loose/rocks - even though the push down test and the side to side tests seemed to be normal with tub returning to the middle - Do you have a recommendation before we call Maytag warranty?
2 heads of screws stripped out - what do you suggest? Is taking this drive hub area off of any benefit? Even though the test for the suspension seemed fine, discovered that the stainless steel tub did rock which may be what was banging against the front part of the machine. Please advise.
Before throwing any more parts at it, though, I would inspect the wash basket and outer tub carefully for any dents, cracks, or damage. Also make sure the basket is sitting straight and isn’t warped. If there’s damage there, replacing the hub alone may not solve the problem and the washer can continue banging and shaking during the spin cycle.
In removing the hub, 2 screws broke off; finally got them out - so missing two screws, in an attempt to substitute a screw, it fell into a slot and seems to have fallen in the hole of the slot - unbelievable!
The replacement of the driver hub appeared to resolve the very loud banging, but now there is the sound of the screw - making a guess here.
Considering the screw went through the hole of the slot, where could the screw fallen to?
If it is impossible to retrieve the screw, will consider living with it until the machine no longer works.
It seems like the screws for the hub are proprietary, could not find a replacement the at Home Depot.
Regarding the ‘replacement’ screw that feel through the slot and hole – where could the screw have gone? Is there a basket over the pump that would prevent it from going into the pump? Removed the back panel and put a light on the outer plastic drum but could not see where the screw could have gone.
So two problems:
A missing ‘replacement’ screw that fell in the slot and hole of the slot when trying to install new driver hub
Missing 2 of the 6 screws for the driver hub (washing with only 4)
