Maytag MVWB766FW0 spin cycle sounds like a jet engine and also shakes the washer
Brand: Maytag
Model Number: MVWB766FW0
The spin cycle sounds like a jet engine. It also shakes the washer quite a bit. The spin cycle still works fine but it is very loud. I have not tried any parts as of yet because I am not sure which parts I will need to fix the main 2 issues listed above.
Based on the information provided, the noise is likely due to the bearing included in the drive assembly Drive assembly. For the shaking, ensure the machine is level, on a sturdy foundation, & check/replace the dampers/suspension rods. Suspension
