Brand: Maytag Washer Model Number:MVWB765FW2 Main Symptom: No Power What happens & when: New Circuit board, Connection to power is good, circuit breaker is good, no power when start button pushed
Parts or tests already tried: New circuit board
There’s a few things on these that cause this other than the main control.
The User Interface W11135393.
The Lock Assembly W10810403.
And the Drain Pump W10876600.
I’d test the lock assembly and the drain pump before condemning the user interface. I’m attaching the tech sheet for this model to help with testing. I’d also check the continuity and condition of the UI harness W10771770 before replacing the UI if the pump and lock check good.
