Brand: Maytag
Model Number:MEW9630DS01
Main Symptom:Neither oven will heat over 110 degrees
What happens & when:Originally oven would not heat at all. I cleaned all connectors, confirmed ohms and voltage to all components finding nothing out of tolerance and verified there were no loose connections or burnt components on the control board.
Error Code (if any):None
Parts or tests already tried:Electrical tests of heating elements, humidity sensor, and voltage test at control board connection. I have not checked the thermostat other than continuity which, when cold is open.
Photos / video link:None
