Maytag MMV6180WS1 3 door switches
Brand: Maytag
Model Number: MMV6180WS1
Main Symptom: won’t start
What happens & when: keypad works, but light flashes, microwave starts, but only for a fraction of a second.
Error Code (if any): none
Parts or tests already tried: see below
I want to replace all 3 door switches. The top has two switches - one with 3 connections, and one with two. The bottom has two connections.
Which are compatible with this model?
W10727360 door switch - 3 connections - says it’s not compatible
W10269458 door interlock switch - 2 connections - says it is compatible
W10269460 door switch - 2 connections - says it’s not compatible
W10211974 door switch - 2 connections - says it is compatible
Again, The top has one with 3 connections, and one with two. The bottom switch has two connections.
Here are links to what door switches would be needed. The 3 terminal switch is W10211972 Microwave Door Switch | Genuine Whirlpool OEM In Stock
The top 2 terminal switch is W10269458 Microwave Door Interlock Switch | Genuine Whirlpool OEM In Stock
and the lower 2 terminal switch is W10211974 Microwave Door Switch | Genuine Whirlpool OEM In Stock
Hi Ed,
Thank you! I replaced all 3 switches (to be on the safe side), and after I put the fuse back in (DUH!) the microwave works fine!
