Brand: Maytag
Model Number: MFT2776DEM00
Main Symptom: Ice Maker not working freezer running warm
What happens & when: Our original issue was the Power Failure alarm continually sounding. We ordered a control panel from Appliance Parts Pros and replaced that. The unit worked well for several days although the unit seemed to run louder than before the control panel change. Then the ice maker stopped working and we began noticing frozen foods getting soft. There is frost/ice over the back panel of the freezer. We checked all connections on the Control Panel to ensure that a loose connection wasn’t causing the problem. Wondering what our next step should be and what parts we would need to order and replace. A less pressing matter is that the refrigerator light also does not work or works off and on which has been a problem for several years
Error Code (if any): Original Code was Power Failure, no codes now
Parts or tests already tried: Control Panel
