Brand: Maytag
**Model Number:**MAVT734EWW
Main Symptom:Not spinning
What happens & when: clothes are wet after wash cycle
Error Code (if any): too old for error codes
Based on my research, it seems it is recommended to replace the thrust bearing. I’m hoping for some diagnosis help. What should be happening inside the washer when I manually turn the pulley (belt removed)? When I turn it counterclockwise (when looking up at the bottom of the washer), nothing happens - no drum or agitator movement. When I turn it clockwise, the agitator turns with no drum movement.
Also, when reaching in from the lid, (belt removed) the drum is very difficult to turn manually. Is that normal?
Thank you for any advice!
