Diagnose noise on Maytag LSE7800 dryer (stack) at start up. Squeals then dies out as dryer spins up. Is this the drum roller(s)that need replacement??
Very likely the problem is a worn out tumbler bearings (#12 on the diagram).
Here are the breakdown diagrams and Replacement parts for MAYTAG LSE7800 Stacked Laundry - Ele | AppliancePartsPros.com
Thanks All…Turned out to be drum roller (ala skateboard wheel) AP4008534 sticking at start up & causing squeal as it loosened and spun up on dryer drum/tumbler start. Accessed by removing panel just under dryer (two screws). I sprayed front & back of roller’s spindle with teflon lubricant. Now roller spins up quietly at start. Avoided ~$240 replace of belt, pulley and both rollers by technician’s estimate. Would have involved moving stack out of laundry closet, opening back and time consuming remove and replace process. ![]()
We are glad you were able to fix it with no cost to you. Good job!
