Brand: Maytag Model Number: MSS25C4MGZ06 Main Symptom: Ice Maker Stop Working What happens & when: The Ice maker will stop working. Defrosting or opening the door for a half hour will allow it to work again
Error Code (if any): None
Parts or tests already tried: Tray and water solenoid replaced under warranty.
I know it has nothing to do with the tray and the solenoid, but that is what they replaced while the fridge was under warranty.
Fridge is no longer under warranty. It seems like the the hose in the door is possibly freezing, because i can leave the door open for a half hour and it will start working again. I believe there is probably heat tape or something on the hose, but I do not see it listed as an obtainable part, except for buying a whole door.
It was a fine temporary solution I suppose, but I’d really like to repair it. Now that it is no longer under warranty, I wouldn’t be voiding my warranty.
There’s a fill tube heater built into the door. If you pull the user interface you should have 1 or 2 connections behind it with white and light blue wires, these will not be connected to the UI in any way. If you’ve got 2 connections like that, 1 of them is to the dispenser heater and the other is to the fill tube heater, if you’ve only got 1 then it is to the fill tube heater. Either way, 1 of the connections should have 2 black wires on the other side of it if I remember correctly, if not go ahead and take a picture of the wires there and post it here. Disconnect that and take a resistance reading on the 2 black wires, you’ll need to use the 20kΩ setting if you don’t have an auto ranging meter, supposed to be roughly 8.8k-10.3kΩ .
If you are getting an open or way out of range reading then the left door W11577825 has to be replaced to fix the issue since the heater isn’t serviceable.
You can also test for voltage at the white and light blue wires there with the freezer door closed, should be 120v AC.
