Brand:Maytag Model Number:MGD5030MW1 Main Symptom:Flame shuts down What happens & when:clattering sound after about 15-20 minutes, then flame shuts off. Dryer will ignite again, clattering sound, flame shuts off. Once cooled down, will repeat the process.
Error Code (if any):No display
Parts or tests already tried:Replaced solenoids.
On your Maytag gas dryer MGD5030MW1, the fact that the burner works normally for 15–20 minutes, then starts clattering and shuts off, is a helpful clue. Since you’ve already replaced the gas valve solenoids and the problem continues, I wouldn’t replace any more parts just yet.
The two things I’d want to check next are the gas valve itself and the burner cycling thermostat, along with the dryer’s airflow.
1. Check where the clattering is coming from
Remove the lower access panel, if equipped, or access the burner area according to your model’s cabinet design.
Run the dryer on Timed Dry with high heat and listen when the noise starts.
Rapid clicking or chattering at the gas valve: Could indicate the valve is failing mechanically or the electrical supply to the coils is being interrupted.
Clicking near the igniter: Could indicate the burner is repeatedly attempting to relight.
Rattling from the blower area: Could indicate a loose blower wheel or something contacting it.
Don’t operate the dryer with safety panels removed unless the service procedure permits it. If you smell gas, stop using it immediately.
2. Check the exhaust airflow
A restricted vent can cause the dryer to overheat and shut the burner off.
Disconnect the exhaust vent from the back of the dryer and run a short, supervised test.
If the burner operates normally without the vent connected, inspect and clean the entire vent system.
If the clattering and flame shutdown continue, move on to the next test.
3. Check voltage to the gas valve coils
This is probably the most useful electrical test, considering you’ve already replaced the solenoids.
Live Power Warning: This test involves 120 VAC. Only perform it if you’re comfortable working around energized components and can safely access the test points.
With the dryer unplugged, connect your meter leads securely across the appropriate gas valve coil supply circuit, using the wiring diagram.
Run the dryer and monitor voltage when the clattering begins.
Voltage remains approximately 120 VAC while the valve chatters: Suspect a mechanical problem with the gas valve, assuming the correct coils are installed and the supply voltage is stable.
Voltage drops or fluctuates when the clattering starts: Suspect an electrical interruption from a thermostat, wiring connection, or control circuit.
The burner cycling off by itself isn’t necessarily a failure. What matters is whether the clattering occurs during a normal heat cycle or is causing an abnormal shutdown.
4. Check the cycling thermostat
If the gas valve loses power, check the cycling thermostat and associated wiring.
A thermostat that opens at its normal operating temperature should allow the burner to relight after the dryer cools. However, an intermittent connection could cause rapid cycling or chattering.
Also, make sure the burner flame is steady and blue while operating. A weak or unstable flame can point toward a gas supply or valve problem.
What I’d like to know next
I have two questions that will help narrow this down considerably:
When the clattering starts, does it sound like rapid clicking coming directly from the gas valve, or more like a mechanical rattling?
When the flame shuts off, does the igniter glow again immediately, or does it stay off for a while before attempting to relight?
Those two observations should help us determine whether we’re dealing with a gas valve problem, an electrical interruption, or normal thermostat cycling.
