Maytag fridge freezer making loud thump about every 5 hrs
Brand: Maytag Refrigerator
Model Number: MTB2156DEW
Main Symptom: Loud Bang from top freezer every 5 hrs.
What happens & when: Working, but very noisy
If you access the evaporator fan in the freezer, does it look like it has ice accumulating around it?
Would this be a thermostat or heater problem? I have no idea how to access the freezer fan.
Thanks,
Mary
I do not believe it is going to be either since it seems like the refrigerator is keeping proper temperature. The back panel of the freezer will have screws at each corner that would need to be removed. This will allow the top of the panel to rotate to the front where the panel can then be pulled out. This will allow the fan to be checked to see if the noise might be coming from it.
Thank you for your help. I will let you know what I find.
