Maytag electric clothes dryer
I have located a broken heating element on the dryer, on the parts to be ordered there are two posibilities a 208 volts and a 240 volts.
Which one should I by?
By guessing I would order the 240, am I correct?
Most likely this is right, but I would make sure what is the voltage at the outlet first.
Thank you Gene, will do.
