The dryer has no power. So far I have changed the cntrl-elec p#ap403950,what else could it be.Thank you
Have you tested all the fuses? If they are good, then you could have a bad relay board. According to the wiring diagram, the power comes to the relay board first, then to the rest of the dryer. Here is the part number for the relay board along with a link to the parts diagram. AP6009648
Is there an eisy way to get to relay board. Thank you
Tony
No, not really. The best way I have found, is throught the front, and remove the drum. It’s a job to do.
